If anyone is running E85, do the coolant temps run any cooler than on gas? I know dragsters running 100% alcohol run so cold they sometimes don't run cooling systems.
no it will not run on E85 if all you do is put it in the tank. requires a tune and draining all the gas out and larger fuel injectors.Fomoco302 said:Basic question from a non-techie -will a stock Boss DD run on E85 ? I thought it had to be a flex fuel vehicle.
Pardon my ignorance :-\
Justin said:no it will not run on E85 if all you do is put it in the tank. requires a tune and draining all the gas out and larger fuel injectors.
if its not around 1 dollar cheaper to get in your area and you are NA dont bother with it stick to 93 its cheaper to run
