Eibach Multi Pro R2 ...debating...input?
PeteInCT
2,848
14
I believe LBP is using Cortex as the supplier if I remember correctly. Lee, jump in here buddy ! ;D
Also, the AST 4150s while only single adjustable have much better valving than the stock stuff and will allow you to run higher spring rates, which is the reason you should be looking at coilovers in the first place. The cool thing about the 4150 is that its upgradeable to a double adjustable down the road. Once you've maxed out what you can get tuning the 4150, and your wallet has recuperated... you can turn them into doubles. The Eibachs are a good value though.
Sesshomurai
Zquez said:
From what I can tell, cortex only offers ohlin, penske etc. rear shocks. The fronts are still their custom valved Konis Mc-strut.
They have front ohlins too. Newly released but special request at the moment.
Check with Filip
PeteInCT
2,848
14
Check with Filip
The fronts are where they were having a fitment issue with the shock mounts for the Ohlins dampers. Hopefully they have the issue resolved.
Grant 302 said:
Just rode in an '11 with KW V3s today. Been following this thread...and now I see why you want coil overs for the track.
Its funny because everybody always says coilovers are overkill. Theyre really not.
