- 873
- 0
I have posted once on adding an shock sensor to the stock alarm on my boss my problem is I am adding a bluetooth radio and it's not cheap well the stock alarm is worthless as to someone breaking a window and taking the alarm there are not to many times my car is anywhere that I have to worrie about it but you know how that works. I have found several add on sensors but most require a wire that when it is 12volt pos would keep the sensor off and when the power is taken away it turns the sensor on so my help question is does anyone know of a wiring diagram for the stock factory alarm. I have contacted several dealerships with absolute zero luck as I figured and all my local alarm companies have no clue nice huh.
