I ran Trick Flow springs in my 3v after I did the cam/phaser mods. They are made by PAC but to their own specs, very good setup that's pretty competitively priced.
Sounds like a good call to me.(snip)...will be going with the RGR short block.
+1 on that update.Great sig photo, BTW
Call Ford Performance and verify that you should or can use the GT350 pump. The pan lists different pickup tubes based if you have a 5.0L or 5.2L engine.
I also suggest you get a pump with billet gears or buy a set of TSS gears.
You might want to check with FP on the cylinder heads as well - the pre-assembled Voodoo heads they sell come with instructions for changing an oil flow restrictor inside the oilway. You use a smaller one (stock) with a Voodoo oil pump and a larger one with a GT oil pump. Presumably this keeps the pressure somewhere in the head from getting too high, so the GT heads may have it as well. Since you're going to be talking to them, you might as well ask.
This wait for the pickup tube is killing me! Supposed to get my motor back end of the month. So close, yet so far.
Right there with you on the pickup tube. I’m still hearing 6 weeks. Anything different there?
5-0l-coyote-435-hp-mustang-crate-engine-m-6007-m50a
Excuse my ignorance, but why spend $13k for a rebuild when you can get a brand new one for $6,600?
