I know when they did mine (replaced the flywheel and pulse ring as well), they had to get a ProCal tool from Ford to perform a relearn. It was throwing codes until they did it. I hope this helps.
We "assume" so. A friend is coming over tomorrow night with his laptop to do the relearn. I have to let the car warm up to operating temperature before we can do the relearn. It's actually going to hit 50 degrees for a high here tomorrow so it won't take all night 8)ArizonaBOSS said:OK FINAL QUESTION (MAYBE):
Did you have to get a Neutral Profile relearn done on the car, since the crank sensor is being removed?
Well that was easy. You just hook the laptop up to OBDII, let the car warm up to 176*, run a short program and rev once to 4k rpm. Outside of the time to warm the car up it's probably a 5 minute exercise.ArizonaBOSS said:Ah, you have a service tech friend...that is convenient. Looks like I'll have to trailer it to a dealer after the harness is replaced, then. In touch with PRS now...
how much Nick?Black Boss said:Pulled the Engine harness today. Not difficult, but tedious, especially if you have big hands. On Gary's advice, I pulled the Strut tower brace, CAI, Intake foam, Coil covers and Injector foam. Also pulled the Oil Breather, Vacuum boost hose and purge valve.
Dropping the harness and sensors off at PRS this week. Current turnaround time is 2-3 weeks.
It did eliminate all the cam phaser issues for me. Were you getting P001x and P002x codes last season?Black Boss said:Pulled the Engine harness today. Not difficult, but tedious, especially if you have big hands. On Gary's advice, I pulled the Strut tower brace, CAI, Intake foam, Coil covers and Injector foam. Also pulled the Oil Breather, Vacuum boost hose and purge valve.
cloud9 said:It did eliminate all the cam phaser issues for me. Were you getting P001x and P002x codes last season?
steveespo said:how much Nick?
You're exactly right on both counts.Black Boss said:Just figured that it was time -- mine's a very early build, and the cost is less than a lost day or two of track time.....
Are you converting to the 12 or 13 harness and sensors? Just doing as precaution? I hadn't heard the Coyotes were having issues but they probably have all the same sensors and harness. ....steveespo said:I'm going to buy new engine harness, solenoids and sensors. Cost is $435, then will send to PRS for conversion. Just in case I break or damage wiring when removing.
The harness has all the engine connections correct? Cam sensors, coils, injectors, pig tail for knock sensors etc right?
Thanks guys, more money spent on a problem I don't have ;D
Looks good. You'll be glad you did it.Black Boss said:Got the harness and sensors/actuators back from PRS:
About to start the re-install....
