- 598
- 536
Tester red or yellow paint pens. Works wonders
This whole "one time use" thing is new to me....I am resisting.I put new ones on when I did the Jri's this time around. Never a bad idea.
Are they even the updated spec with the fine thread?They are probably one time fasteners that I've used 50 times already.
That. And clean most of the old loctite off.oh, I use them over and over to a point, then I put new ones in, Blue lock tight every time I put the back in though.
It will be fully addressed after tomorrow. Right now its just hella tight.That. And clean most of the old loctite off.
Might also want to fab a key or slug to fill the open side of the slot.
There's an updated bolt? These are from 2006 when I bought the car.Are they even the updated spec with the fine thread?
Yurp.Right now
I don't even think you can get the *old* new ones any more from Ford only the *new* new ones.And he needs new *new* ones, not new *old* ones!
I think you can. Looks like the old part numbers still work and have available inventory.
Maximum Motorsport also has the new ones in a 'kit' available for ~$22/strut. (2 nuts and 2 bolts/kit get 2 per car)
Thanks!I'd have to look it up but I thought higher than 8. My memory isn't what it use to be.
Nice improvements!
