- 6,361
- 8,181
that's getting close to the zoomy stuff in the GTD class
Between you and @Mad Hatter this is ri-@#$%ing-diculous...in a good way. I think you guys have found the secret sauce for these motors for power and longevity. With the trials you have put up with this feels like the whole project is reborn. You look at older GT500s making 500-something horsepower but having to keep up with cooling and even the first GT350s, you guys seem to have discovered the perfect balance. This is awesome.507/414 on Shaun’s dyno. That’s 31 hp and 17 # torque across the board. Still not bad for an all stock motor.
Wow! All the secret sauce really makes that sucker come alive past 5500. What I'm seeing that I think is extremely impressive is how it gets to and how long it holds a flat high hp power band. Darn near 2000 rpm! Most dyno sheets I've seen don't hold that long. There's some magic in that engine and tuning.
Thought I would add this for anyone considering upgrades and target whp numbers. It’s amazing the HP to be had with intake mods. You’re 79 whp higher than I was on the same dyno. Shaun thought I was giving up a bit with the heavier rotating assembly of the built short block vs stock Gen3. But the real magic is the combination of the worked Gen2 heads, intake cams, CJ manifold and CAI, vs. my Gen1 heads, stock cams, Boss 302 intake and stock air box.
To @KazarS197 ‘s point, the “art of the tune” must have something to do with the flat power curve - mine is very similarly flat from 6k-8K.
Question please. I watched my pulls on the dyno and seem like they took so much longer than many others I have seen. ( Mustang Dyno) I have decent numbers @ 424 and 383 on 92 for basically bolt ons. Not sure if my intake is ported. Was on E85 but "detuned" due to track and location availability. I can't figure out the why my pulls are longer. I told him to give me a safe tune the whole way through the curve and don't lean me out just to show better numbers. Did my tuner put a different load on the dyno so he could look at things closer - kinda like a slow motion data so he could make more specific adjustments. It would be cool to see a dyno thread from independent tuners, not to disclose secrets but for the rational to reach a goal of a tune. - preferably track specific. My stuff is in my build thread. Sorry for the derail.
