Factory 2 Step Question?
I am trying to use the 2 step. I hold the set button and watch the tack move up. Then I move the tack to 4000 rpm. Then when I put the gas pedal to the floor, the motor only revs to 2000 rpm and stalls when I dump the clutch. What am I doing wrong?
8,721
2,715
Sounds like you're not pressing the "ON" button after getting the tach where you want it (sounds like 4k RPM).
http://www.fordracingparts.com/trackey/include/TracKey_Customer_Instructions_V1.2.pdf
I have print outs of that and how to do the Traction control, I always forget if 2 quick or one long is all off. I also have the pit speed one and something else that I never look at.
Pressing the "on" button, did the trick. Thanks. If it doesn't rain for the 30th day in a row tonight, I'd going to make a few 1/8 miles passes with drag radials to see how my 60 ft times are.
