- 6,394
- 8,275
I think everyone agrees across the board that the most dramatic effect comes from the tire/ wheel package, that is by far, the easiest ( maybe not the cheapest) change that makes the biggest difference.@Run_Amok, lots of good replies on this thread. Here's another vote for Billy Johnson's article over on moto-iq, it's excellent. A couple more thoughts in response to your questions:
1. No, I don't think corner-balancing adds very much at an intermediate HPDE level. I'd put it lower on your list.
2. Some of the best advice I got was to pick your track tires first and then find track rims to work with those tires. The biggest decision here is that most true race tires for Mustangs come in 18" diameter but the majority of good 200tw "tweener" tires are in 305/30/19 or similar. So you sort of have to decide what type of tires you want to use.
3. PHB vs. Watts seems to be more personal preference than objectively one is faster than the other. Plenty of very fast cars using both. As true racers on here have explained (@Fabman etc.) my understanding is one of the biggest advantages of the WL is you can adjust rear roll center, and thus rear roll stiffness, pretty easily. I think a lot of the reported "improvement in driving feel" posts you see with a WL comes from what is sometimes a lower roll center. But you can get similar results and benefits by softening your rear roll rate, such as by removing or reducing the size of the rear roll bar which is easy to do. Billy's article has the details.
I'm not familiar with your SR springs but yes, I think you do want adjustable rear LCA brackets if you have lowered the car significantly. Which it seems you have if you were in need of a front bump-steer kit?
IMO your next best ROI upgrades are good wheels and tires and front camber plates.
Do that, do the camber plates, and see where that gets you. I think you'll be surprised.
And FWIW, the " golden" sway bars are the Ford " blue" bar, and the 18mm or no bar in the rear, I forget the part numbers, but some of these guys will have them.
