First gear ......
Fomoco302
Life is short. Live well!
Bear with me folks I am not naturally mechanically inclined and I marvel at the work some of y'all do to your cars. Question - first gear is so short when moving from rest I tend to use second gear. I do not slip the clutch excessively and I always try to roll up to lights and time it so I don't make a complete stop and pull away in second. Am I hurting the clutch long term ? Your advice is most appreciated.
98% of the time I start with 2nd gear as well, but this is my first manual transmission car. so, dont take my word for it lol.
I've had the car for a year, and haven't had any clutch issues... and I learned how to drive stick on this car.
I grew up with manuals. This baby is geared so tight, the only time you'll need first gear is if you're racing. Gear has nothing to do with clutch etc. I use second gear from starts all the time. It's less "bucky".
No problem at all starting off in second gear. I do it all the time on the street for the same reasons. By comparison, the MT82 2nd gear ratio is 2.43; the old close ratio toploader tranny had a 2.32 first gear.
1,473
397
Are the tracks you go to that tight? Every track I have been to out west you hardly ever go down to 2nd let alone ever going to 1st.
OP- If anything I skip 2nd, but I always start in 1st. Plus we have speed bumps in parking lots here in CA so with as low as my car is there is no way I could go over them in 2nd. My car is too low for my liking with 18s and H&R Race springs. Clearly there is more slip and more wear starting off from 2nd but I'm not sure if it's enough to really make a difference long term or not. Overall # of starts is probably the greater driver of long term wear.
+1, I've been doing this for 30plus years, never an issue.
Just don't do it in front of five-oh...
Don't ask how I know..
EDIT - Removed NSFW comment
If you're on a dragstrip. I go over speed bumps in second. It's just so easy to finesse the clutch/gas that I only use first gear while warming the car up.
1,473
397
Ahhh ok, forgot about drag strips. I do very much the same thing with my crew cab 4x4 diesel six speed manual. It has a granny L which I'll use from time to time especially in stop and go traffic, 1st which I usually go to when starting, and 2nd which if I'm moving at any speed at all I can easily pull away in. Lately I've been "skip shifting" and going 1-3-5 or 2-4 or 5 and believe it or not it's had a significant impact on mileage. LOL I get better avg MPG in my 6800 lb truck than my Boss. ::)
