Bought this kit used, seems the hose running from the intake to the can is a bit cramped. Does this look correct to you all? From what I’ve read it’s a universal kit for all 2011+ gt / boss 302 and gt350.
That looks ok. It is tighter than what I originally had on my GT but the Boss probably has a wider radiator.
I upgraded mine to the Ford Racing Radiator and it is so thick that it pushed everything closer to the engine. So much so that I had to attach my stock coolant tank to the fan j-clips with zip ties instead of the stock bolts. Even with that, the coolant tank rubbed on the separator. I replaced it with a Moroso coolant tank that is much thinner than the stock unit.
Thanks for the response, i definitely feel like the GT with the lower intake would allow a bit more room for that connector. But should be fine, will keep an eye on it!
