A trans cooler would be ideal but it is definitely better than nothing, I noticed a significant decrease in the heat coming through my center console and shifter after installing the trans scoop.I've seen a few comments here and there about this but nothing definitive. Is the Ford MT82 trans scoop worth getting for track use or is it a waste of money?
Thanks in advance!
I have one and yes its worth it. Std on LS Boss. Only thing is you have to remove it to change oil unless you have some way of directing oil away from it on Sn197. Im not sure on SN550 cars cause the scoop looks different
Your trans is probably getting hotter than you realize, I build up lots of heat even on winding road drives and noticed a big improvement there too, not just on the track.Thank you all for your input!
I'm new to this and only doing HPDE events at the moment so I doubt my tranny is getting all that hot but I like the peace of mind.
As this car is also my daily, any concern of the scoop hanging too low and scraping on speed bumps or anything? Or should I only have it on for track days?
Well there are differences in the transmission itself as well as the obvious fascia and other aero differences, it is possible that the 2018+ don't need it!Steeda claims that at least the 2018+ MT-82's don't need trans cooling, apparently. Any thoughts on this?
I'm too lazy to do that! I have a real big oil drain pan, would probably just open 'er up and let it drool down the scoop into the pan for 24 hours or so, then wipe the scoop off! Or maybe you can't get at the oil drain bolt with the scoop on there?
Now if only someone could figure a way to mount it with the BMR K-member... I did contact BMR but they offered no solution. I figured I'd have to find another mounting point and weld on some different mounting arms. Never enough tyme in the world to get to all the things I'd like to do. Perhaps I'll find a remote cooling system for the tranny. Right now it's the only part of the system I worry about temps on the track.
