Ford's "Have a Good Time at the Track" plug.
Discussion in 'Drag Racing Forum' started by LERCH, Sep 30, 2017.
  1. LERCH
    LERCH TMO Intermediate
    91
    24
    May 13, 2015
    Apparently this isn't new information to some people, but I thought I would post it up here. I was at the track last night, and met another S550 owner who used to be a ford tech. He showed me this little jumper plug Ford put in the traction/stability control system. When removed it completely disables both systems. I plan in cutting the wire, and installing a interior switch so I can turn it on or off from inside the car. tcs jumper.jpg tcs plug.jpg
  2. VoodooBoss
    VoodooBoss Rick Moderator
    20,390
    2,774
    Nov 30, 2010
    Interesting, thanks for posting. Not sure how all of that works on the S550 but on the GT350 it works very well. I run my car in Track Mode and don't turn off TC or Advance Trac. It rarely interfere's. Unless you're having issues with it interfering I'd be cautious about removing it.
    @OPMustang Tim
    @captdistraction
  3. mnmike59
    mnmike59 TMO Advanced
    101
    64
    Jun 15, 2016
    Prior Lake
    Very Interesting!
    Where is that located? I don't recognise the surroundings in the photo. If this is true, I wonder if disconnecting this would help with the differential overheating issue?
    As far as it interfering, High-speed corners like BIR turn 2 at 120 mph throws my car around like like I'm having serious suspension issues.
    EDIT TO ADD: Does this disable the ABS? If so, I wouldn't be interested. ABS IMO can save your butt in some cases.
  4. ArizonaBOSS
    ArizonaBOSS Because racecar. Moderator
    8,169
    1,763
    Dec 6, 2010
    Looks like in front of driver's side strut tower right next to the airbox assembly.
    The_Dead_Cow likes this.
  5. Black Boss
    Black Boss TMO Addict
    1,660
    1,232
    Sep 29, 2012
    Michigan
    Yes, Looks like this -- need to investigate :)
    ArizonaBOSS likes this.
  6. yotah1
    yotah1 TMO Race
    224
    281
    Mar 22, 2017
    Detroit
    That would make my life easier at trackdays so I don't have to go through the buttons to switch everything off everytime I start the car ... I'll look into it on my car too :)
    Thanks for the tip!
  7. RES_22
    RES_22 Rob
    239
    235
    Dec 25, 2016
    Snowy North
    Confirmed.
  8. mnmike59
    101
    64
    Jun 15, 2016
    Prior Lake
    I'm still waiting to hear if this disables the ABS?
  9. RES_22
    RES_22 Rob
    239
    235
    Dec 25, 2016
    Snowy North
  10. JDee
    JDee Ancient Racer
    407
    385
    Oct 10, 2017
    halfway between Mosport and Shannonville
    RES_22 likes this.
  11. tracktardicus
    tracktardicus TMO Intermediate
    36
    37
    Mar 16, 2018
    Denver CO
    I wanted to follow up on this thread to poll users on their experiences, good or bad, when they remove this plug. Pros/cons?
  12. Drlee50
    Drlee50 TMO Race
    253
    119
    Sep 3, 2017
    US
    When you switch to slicks it can really throw off the system as its calibrated. I would suspect worse on a regular GT vs a 350. The calibration is probably very different between the different makes. It wants to intrude when it senses significant yaw that would be beyond what a stock radial tire can hold. Slicks on the other hand, especially over sized square setups, can create far more grip and thus G-loads etc causing the stock calibration to attempt to save your ass, when really, the slicks will hold just fine. In my experience with GTs and even the BOSS, the system doesn't go totally off when you shut it off. Hopefully this plug does disable it completely. For the boss, the only solution was the Boss 302 abs module change. I dont have a 350 so no idea on that. But it appears this plug is needed to disable it totally as well. nice of ford to install that gem!
  13. tracktardicus
    36
    37
    Mar 16, 2018
    Denver CO
    Specifically, has anyone tracked their GT350 with slicks with this connection unplugged? If not, I guess I'll be the guinea pig and post results.
  14. Nvrfinished
    Nvrfinished TMO Advanced
    182
    165
    Jul 6, 2017
    SoCal
    I need to experiment with switching the Advancetrac off from in the car first before I disable it from the engine compartment. In track mode on my GTPP I'm occasionally experiencing issues where power is being cut when I want to accelerate anywhere from mid corner to corner exit. I feel like it does not like the car being close to the edge of traction in those situations.
  15. ArizonaBOSS
    8,169
    1,763
    Dec 6, 2010
    Yes, we have run the 350R w/ Hoosier R7s with this unplugged.
    After a time (7-8 sessions) we experienced loss of power steering assist at startup. Plug it back in and it went away in a few miles. Didn't happen while driving on-track.
    The_Dead_Cow and tracktardicus like this.
  16. tracktardicus
    36
    37
    Mar 16, 2018
    Denver CO
    Not sure what suspension you are running, but what were your impressions on driving dynamics with the TC fully disabled compared to the Track setting?
  17. ArizonaBOSS
    8,169
    1,763
    Dec 6, 2010
    Suspension was stock stuff. Never tried it with it plugged in.
Share This Page
