Forgestar F14 lug nuts
2012Boss302 said:
I just ordered some Forgestar F14. Will the factory lug nuts work or do I need to buy some of the smaller type??
Pretty sure you need the smaller ones. Vorshlag makes a good, beefy set that is small enough.
5,237
4,227
Sorry my bad... this is from the American Muscle website...
Note: The stock lug nuts (13/16”) prove to be too large when used in conjunction with these wheels. Please take a look at the Lug Nut Ordering Options above for some compatible options.
Dig-It
Kevin
237
8
VA
For my Forgestar CF5s, I'm using a 3/4" open lug nut with the FRPP ARP studs. Gorilla makes a 3/4" socket with the narrowest outer diameter I could find that fits the lug well of the Forgestar. It's still a very tight fit, but I wanted to use open ended lug nuts and not the "Acorn" type from American Muscle.
I ran the Forgestar 14s all last season. At first I thought I need the small lug nut and ordered a set at the same time I ordered the wheels. I did not like how much smaller they were and simply tried my Gorilla 90087 lug nuts with a thinner walled socket. That worked great and all but one of my existing sockets worked just fine to fit into the smaller opening.
