FP350S Video
Hello,
Here is a link to a video on the Ford Performance facility that is making the FP350S. There is also a short blurb on the new Bullitt and the Ford Performance power pack upgrades for the GT with dyno pulls.
A couple things from the video
Oil Cooler / Differential Cooler
They have installed a larger oil cooler at the bottom of the radiator. They used the stock GT350 oil cooler as a differential cooler. Had problems with the stock GT350 differential cooler in the rear of the car.
Brake Cooling
Here is a shot of the brake cooling adapter for the spindle. There doesn’t seem to be any sign of how it’s attached to the spindle. They for sure aren’t using the three mounting holes for the brake dust shield. Wonder of it’s mounted to the bottom two bolts of the shock?
Bump Steer Kit
There is a bump steer kit on the front spindle. Does anyone know who makes the Bump Steer Kit? You can also see it in the picture above.
Larger Oil Pan – Anyone have a part number?
Radiator Ducting for better cooling
Engine Breather System
Peterson Fluid System – Anyone have a part number?
I know they have a catch can for the coyote but this seems different with the return line to the oil pan.
215
The oil pan is made by Watson. Its based on the 302S pan with some tweaks. The peterson breathers are built for Watson to their specs. Call Watson and ask if there is a plan to make them available to the public. A lot of the 302S parts are still sold by them. They sell 2 versions of the Peterson breather but they are both different from the one installed on the FP350S.
Watson is a great place and the staff are cool peeps...
