FWIW Lisle, or maybe Snap On, makes a ratcheting type pad expander that works real good. We welded 2 plates on ours to make it easier because it was mustang specific.
Looks like this...well, look slike IMGUR folded, so maybe later
There is a very simple tool sold by Full Tilt Boogie
It's really a 3" wide flat steel, with a 20-deg bend near the end. Then a 1/4" bar welded at 90-deg. It's a very easy tool to use. Leave one pad in, put this tool in where the other pad was, and use the cross-bar to push in the two pistons. Then place the new pad in that space, and repeat for the other pad. It makes swapping the pads take about 5-min per corner, including jacking up the car, and removing the wheel.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
