Front Rotor Cracks
HardYakka
Avalanche Gray '17
@StigsBaldBrother great point re: cross-drilled rotors. I've never had a pair so, learned something new. Makes complete sense now that I imagine the process.
Oh, so my lowest caliper reading up front was 35.6mm and I had to hunt around for that outlier. most where 35.8.... so the Stealership earns its reputation, once again :)
492
387
DFW, TX
Turning rotors with holes is not really any different than with slots. You can always increase the rms finish, more like the final pass instead of a quick initial cut.
Unless they are warped, why bother.
I think these rotors "float" radially not side to side, so you might be able to cut them...maybe?
Cleaning the holes periodically might reduce your rust. They do get packed with pad and iron dust easily.
8,425
8,356
When you do get a new set of rotors I would recommend looking towards a set of slotted rotors instead -- Girodisc makes a great set and they are made in the US. I have never been a fan of drilled rotors , I am hard on rotors and have cracked the sets I had fairly early.
