S197 FS Koni Yellow SA Rear Shocks Cortex Setup
100
109
Utah
I am selling a pair of rear Yellow Koni SA rear shocks used in a Cortex suspensions setup. As shown, these are the true Coilover - double eye - setup. A ture coilover means that the rear shock spring is mounted on the shock and Not on the axle. I had no clearance problems with a 2 1/2" dia spring and 18x11 wheels with a 315/30/18 Hoosier tires. They have been used for a about 12-14 track days. $100 + shipping/feesIMG_4434.JPG
109
Utah
Yes by true coilover I meant the the rear spring mounts on the shock and not on the axle as a regular. Mustang shock.
100
109
Utah
Yes just the bare shocks, no sleeve, no bottom spring support and this also means the you need the bracket for the top shock eye to mount to the car. It is a replacement shock if you have the Cortex coilover setup and need to replace a shock or keep as spares.
