Fuel Rail / System Pressure - Too Low Bank 1
Hi guys
I hope I posted it in the right place.😅
Does anyone have the error code P0087?
Yesterday at the trackday the engine lamp appeared with this error code. 🤮
Car has suddenly lost power, a bit engine stuttering and there are "backfires".
(This only happened in tight fast corners!)
0:10 - 0:19 sec.
0:39 - 0:48 sec.
-Temperatures were all okay, Oil pressure too.
-The gas tank was full.
-I already had the problem a month ago on a pass road with fast corners. Did not show up after that with normal driving.
The ford garage wants to change the fuel pump, but I don't know if this is really the reason.
I thank you in advance for your help.
I had a somewhat similar issue to yours but I was getting a P0300 and P0197 code. My issue ended up being a short in the engine harness at the fuel rail pressure connector.
Do you have any OBD scanning software? Try logging your fuel pressure and signal voltage you may have a similar issue.
There's also a TSB regarding a loose transmission output shaft nut that can apparently cause intermittent hesitation as well. My output shaft nut was loose but wasn't the cause of my problem.
Gasoline Engines PCED
Fuel Pressure, Fuel Rail Pressure (FRP) And Fuel Rail Pressure Temperature (FRPT) Sensors
Introduction
  • specs.pdf
