GT Performance Pack Level 2: Game On!
Norm Peterson
Corner Barstool Sitter
939
712
a few miles east of Philly
Thanks for your input Norm. I thought there may have been a clearance problem of some sort. It’s unfortunate that you can’t rotate the tires without breaking them off the rims.
If you avoid 'unidirectional' tires, you can at least swap left to right, which is better than doing nothing at all given that all tracks have 360° more of turns in one direction than in the other. My sig picture shows 18x11 front wheels.
Norm
4,008
1,924
I will be checking offset on the 19x11" rear PP2 wheels and will report if they will work on the front, probably with a 25 mm spacer they will. Ford Performance is almost sure to offer these wheels in their catalog for reasonable price. I would then run the Michelin PS Cup2 tires in 315 square.
You are going to run 315 on the front? I’d like to hear how that works.
Norm
And then there’s the old trick where you flip the tires on the rim and move them to opposite sides. Keeps the direction the same but still requires a dismount. Used to do this on a 5.0 years ago, until I got a proper alignment.
492
387
DFW, TX
If you look closely at the specs for the "GT350R" Michelin PS Cup2 315 tire, it sure looks like Ford had Michelin maximize the tread width while minimizing the section width. They are really a 325 with less section width.
I use the same 11" wide wheels front and rear so I can rotate the tires and wheels.
What's up with the K brace?
I wonder if the PPL2 was not offered with the 10 speed auto because it would be faster than the GT350?
Hey Rick, how are the 11s working up front? Any clearance problems, did you need spacers? Can you order those instead of the 10.5s?
