GT350 blown engine
Discussion in 'GT350 and S550 Technical Forum' started by dchunk911, May 13, 2018.
  1. dchunk911
    dchunk911 TMO Intermediate
    10
    May 13, 2018
    Florida
    A GT350 ventilated the block yesterday at PBIR. This particular car had 4000 miles and seven track days under her belt,
    Have there been issues/blown engines tracking the FPC engine?
  2. VoodooBoss
    VoodooBoss Rick Moderator
    19,922
    2,349
    Nov 30, 2010
    Is it your car? There have been a few. The oil pump gear has caused some of the failures.
  3. dchunk911
    10
    May 13, 2018
    Florida
    Not my car, a gentlemen from Orlando, FL. I’m tracking my 350R and want to proactively avoid that situation.
    Has Ford stood behind the failures, when the car is tracked?
  4. VoodooBoss
    19,922
    2,349
    Nov 30, 2010
    Yes. Mine had the OPG fail on track and it was fully covered under warranty.
  5. dchunk911
    10
    May 13, 2018
    Florida
    Did they upgrade the OPG? Seen mention of a canister oil filter in place of the spin on. Has Ford changed the filter?
    I’m relieved to hear Ford stood behind you. I love this car as a track car and everyone’s got me panicked to get back in a GT3!
  6. dchunk911
    10
    May 13, 2018
    Florida
    The failed GT350 is at a local dealer, I will report back with the outcome, what exactly happened.
  7. VoodooBoss
    19,922
    2,349
    Nov 30, 2010
    We'd like to hear the outcome if there is any additional info to share.
    Officially there is no issue with the OPG so it was not upgraded. Unless Ford made a running change it uses the same gears as the ones that broke. My replacement engine came with the oil filter canister but the dealer told me that they needed to remove it and use the spin on oil filter because that's the way my 2016 was built. I was not happy nor was I happy with the two months my car sat at the dealer. I'll stop there.
  8. OPMustang Tim
    OPMustang Tim TMO Race
    246
    199
    Jul 9, 2016
    Sunny Florida where it does not snow.
    Parts fail, Ford Performance is very good about handling these, the dealers can be hit or miss. We do offer a GT350 oil pump with Boundary Gears. Once we receive in more gear sets we will be offering them on our website. We have had multiple requests from GT350 Customers with the same concern. A vast majority of these are owned by Track Users so if something can fail it may.
  9. dchunk911
    10
    May 13, 2018
    Florida
    I agree, but I have fifty year oid Porsche air cooled race engines that still have the original case hardened steel oil pump gears.
    What’s the change out procedure on the FPC motor? Engine out, I assume.
  10. dchunk911
    10
    May 13, 2018
    Florida
    FP does have an upgrade CNC billet steel Oil Pump Gear, p/n M-6600-M50A. The complete oil pump assembly is p/n M-6600-M52
    The gears can be replaced without removing the oil pan, just remove the timing gear cover.
    Question: Would you have to re-time the cams?
    Also, an oil canister conversion kit, p/n M-6881-52CA does fit 2015-2017 5.2 FPC motors.
    FYI
  11. VoodooBoss
    19,922
    2,349
    Nov 30, 2010
    To be clear the OPG part number does not come on the voodoo motor. It's an aftermarket part sold by For Performance that you can buy and install. The stock engine does not include an upgraded CNC OPG set.
  12. dchunk911
    10
    May 13, 2018
    Florida
    Roger that.
    FP recommends the billet part if it's modified or beat on.
    I found it curious that FP says the oil canister kit retrofits, but they wouldn't put it on your '16 at engine change out.
    RES_22 likes this.
  13. byronj
    byronj TMO Addict
    1,336
    275
    Jul 17, 2012
    Bay Area
    Wait, what???? My buddy’s 16 Tech Pack has the canister.
  14. VoodooBoss
    19,922
    2,349
    Nov 30, 2010
    It was added later.
  15. byronj
    byronj TMO Addict
    1,336
    275
    Jul 17, 2012
    Bay Area
    Ahhh, well I’m sure I’m fine. Still loving the car. Had a neighbor stop buy. He’s in the market. I told him to join here to get some good info.
    VoodooBoss likes this.
  16. VoodooBoss
    19,922
    2,349
    Nov 30, 2010
    The canister was a mid year change on the 2017 cars and that’s when it became available as a retro fit kit.
    byronj likes this.
  17. byronj
    byronj TMO Addict
    1,336
    275
    Jul 17, 2012
    Bay Area
  18. dchunk911
    10
    May 13, 2018
    Florida
    #8 connecting rod failure, quarter size hole through the block. Ford has instructed the dealer to "secure" the engine and send it back.
    Dealer will R&R with new engine under warranty.
    Tried to upload a 2.85 mb photo but got this pop up: The uploaded file is too large for the server to process.
  19. VoodooBoss
    19,922
    2,349
    Nov 30, 2010
    #8 is very common on the Coyotes. Ask me how I know. ;)
    I’ll check the file size as I ran into that yesterday as well. Should be set at 5mb.
Share This Page
