GT350 Flat-Plane Crankshaft Explained
Discussion in 'Drivetrain, Exhaust and Electrical' started by VoodooBoss, Nov 23, 2014.
  1. VoodooBoss
    VoodooBoss Rick Moderator
    19,960
    2,395
    Nov 30, 2010
    Not that the GT350 has been confirmed to include a flat-plane crank I'd like to learn more about it. The two main purposes for using such a design is to lighten the rotating mass and improve breathing. A FPC uses a lighter crank which allows the engine to rev up faster. The firing order allows a better flow from the exhaust ports. One negative is they typically have less torque. The GT350 will either have a 8,000 or 8,250 RPM rev limit depending on how you interpret this comment:
    "The new Ford spins to a heady 8000 rpm before fuel cut-off, according to Nair, and has another 250 rpm of safe headroom. This from mildly oversquare 94 x 92.7-mm bore and stroke dimensions."
    More can be read at the links below. Post up any insight or questions you may have.
    http://articles.sae.org/13709/
    https://www.youtube.com/watch?feature=player_detailpage&v=2AzrOPPZFzs
    http://www.projectm71.com/Cross_FlatPlane.htm
    [​IMG]
    [​IMG]
  2. twistedneck
    twistedneck TMO Race
    315
    29
    Oct 15, 2014
    Dearborn, MI
    I thought you didn't need the heavy counter weights with the flat plane? but balance shafts were needed? still confused.
    Excellent schematics and animations.
  3. VoodooBoss
    19,960
    2,395
    Nov 30, 2010
    Most FPC engines are smaller displacement. Hopefully the added counterweights and crank are still lighter than the cranks in our engines.
  4. Fat Boss
    Fat Boss TMO Addict
    1,186
    122
    Mar 24, 2011
    Funny that Ford used the FPC's over a hundred years ago. ;D
    Model T crank.
    [​IMG]
  5. VoodooBoss
    19,960
    2,395
    Nov 30, 2010
    GT350 Flat-Plane Crankshaft Explained Vintage Article
    This is from member Psg8064 who forwarded this to me for posting. It's a pretty cool read. I have the PDF but thought this might be easier for reading. Let me know if it's not. Click on the images to make them larger or download them.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  6. ChopSui
    ChopSui Mike
    177
    33
    Apr 6, 2014
    Austin
    Awesome, depleted uranium counterweights!
  7. VoodooBoss
    19,960
    2,395
    Nov 30, 2010
    Here's an interesting article on the FPC configuration Ford used. Not conventional and not light either. It will be interesting to see how it holds up to @cloud9 on track. ;D
    http://www.edmunds.com/ford/mustang/2015/long-term-road-test/2015-ford-mustang-gt-more-insights-on-the-gt350-voodoo-v8.html
    GT350
    [​IMG]
    Porsche 918
    [​IMG]
Share This Page
