Received and installed. Pagid Yellow RS29’s are also inbound (Thanks, Tony) Can’t wait to try these out!!
Looking good. When do you get to test yours out? My next track day is Sept 25 at Sonoma. Also, when will you be in CA for the winter season?
Did you just run up to Bellingham to pick those up?Received and installed. Pagid Yellow RS29’s are also inbound (Thanks, Tony) Can’t wait to try these out!!
I should have, but I was dissuade by the prospect of free shipping and receiving it next day.Did you just run up to Bellingham to pick those up?
I'm not sure what you mean in your first sentence. The answer is, yes, you have to remove the caliper to remove the rotor (and you have to have the handbrake off too). The spring and handbrake cable end (upper picture) have to be undone to access the two bolts that hold the caliper on.So we cannot get away of removing the rear rotor by just removing the caliper like you could with the fronts?
Reviewing the service manual, it states these two bolts have to come out and thrown away and re-installed with 81 lb/ft of torque.
I'm hoping that's not the case that they do not need to be thrown away or that it has to come out to replace the rotor.
Are you guys reusing the YTT bolts that should be thrown away according to the manaul or replacing it with unknown part number? It sounds like I need to purchase some tools for the parking brake. Sadly, a lot of the different tools offered here are no longer in stock or unavailable to purchase. Any other suggestions?
