So what would a GT350LX be like? Well, the "LX" implies a luxury ride, quiet and composed regardless of conditions outside. Think of it as the other end of the spectrum from an "R". Ford didn't make an LX version - it didn't fit the brand image - but that doesn't mean that a GT350 can't be tuned to deliver a very composed driving experience for daily use.
So why would I do this? The short answer is that I learned how to manage the vehicle dynamics after I set off in search of tuning options that would make the car "easier to drive fast" back in 2017. I've definitely achieved that goal - it's fabulous at speed - and I've discovered a few collateral benefits along the way.
So what are the key components of the "luxo-version" GT350? Suspension, electronics, brakes and tires. How hard can it be?
First - suspension:
1. DSC Sport controller. I've programmed and test-driven over 225 different calibration files for this controller. Everything I could possibly try has been tried. My version ended up surprisingly close to the latest one on the DSC website, but I made a few changes in the comfort settings to smooth out the ride and added travel stops to keep the splitter off the ground when going over speed bumps.
2. Springs, struts and shocks - GT350R struts, rear shocks, front springs and rear bar. The regular GT350 shocks are good but the R parts are easier to tune and the stiffer springs reduce the tendency for front-rear pitching. I use Steeda strut tops - they re-use the OEM upper spring perch to block road noise. The Vorshlag units I tried first were beautifully made, but the road noise got tiring after a while.
3. Other chassis improvements - the Steeda cross brace behind the engine made a surprising difference in chassis stiffness. Noticeable immediately. The rear subframe braces also channeled road noise into the cabin and didn't seem to make much difference otherwise so I took them back off.
Second - electronics:
This is one of the major projects I did on my Track Pack - it came with the 4" display and I wanted the 8". I've replaced the electronic modules with 2017 parts, giving me Apple CarPlay, Android Auto, HD Radio, SiriusXM music and traffic. This is a fairly common upgrade, but I also finished the job of integrating the heating system controls.
The Track Pack lacks a number of sensors and actuators that the climate control module needs to work correctly. Without them, it does provide a limited form of "climate control" instead of manual heater controls but it doesn't really work that well and the module presents five unclearable error codes on the OBD port.
I took the (considerable) time to figure out all the parts needed so the dash controller would be happy (no codes now) and I now have real climate control that works beautifully, although it's not split left-to-right like the Tech Pack.
Third - brakes - this is easy - CCB front rotors, Racing Brake XT910 street pads in the front and Raybestos EHT pads in the rear. Super-smooth - no dust, no noise - perfect for the street.
Tires and wheels - this is kind of fun too - so I had a set of front Base rims for a 2013/14 GT500 sitting in storage. They're 19x9.5" and they look great in a slightly smoky silver finish. So, they now have Michelin AS/3 tires in 255/40x19 front and 265/40x19 rear. Those tires are an EXACT diameter match to the OEM GT350 tires in 295/35 and 305/35.
These rims are ET44 so I'm running the front tires with a 24mm spacer (gives me ET20) and the rears with no spacer. They clear the brakes just fine, they look great, the tires are quiet, there's absolutely NO tramlining and I'm no longer the slightest bit concerned about driving through standing water on the highway.
This setup also saved me the trouble of changing the front hubs - I have GT350R front hubs with the super-long studs. The 24mm spacers mean I can run deep Gorilla closed-end lug nuts on the front and not-so-deep McGard closed end lug nuts on the rear (chosen because they both take a 22mm socket).
So, that's how you make a GT350LX. With the "R" parts in the suspension and with the DSC module, you get great track handling and a great ride on the street. Swapping track tires and brake pads for street versions makes the car a lot more user friendly if you just want to drive to work.
First - suspension:
