Harry's Lap Timer and iPhone 7 -- jerky video
I just switched from iPhone 5 to 7 and now the video is very jerky. I am using the same Ram mount as before. Harry's compatibility page says iPhone 4S is the best for video. But... surely there is some setting or other work-around that will produce better video than this:
https://youtu.be/l3iRpHv1vPQ
Thanks.
Jim
It's called "Jello effect"
https://en.wikipedia.org/wiki/Rolling_shutter
I had the same problem and I installed this kind of stuff between the mount and the Iphone.
http://www.helipal.com/lp-0064-jello-killer-vibration-free-camera-mount-base.html?osCsid=6bbflq0t426jsoodfnl3p8hkb3
It helped a lot but didn't cure it 100%. I'm pretty happy so far.
Here's link to my youtube video where you can see the difference. The older ones a very shaky like yours and the newer ones are much better.
https://www.youtube.com/channel/UCp2sKNbVcekKlPJxcdWxFxw
6,551
8,203
I noticed that my iPhone 7 video is way shaky too.
I didn't have that with my iPhone 6. I always got great video.
I'm using TrackAddict and there is a setting in there that will stabilize the video I found at the end of the last track day. Maybe your app has a similar feature.
899
545
Would you post up a few pictures of how this is used to mount an iPhone? I have the same problem with my iPhone 7.
Thanks.
Jim
Which RAM mount end are you using? X-Brace or one that fits the iPhone7?
The X-Brace is much more prone to vibration, according to Harry.
I use a "Tough Claw" from Ram mount to fixed to the roll bar then an articulate arm with a round plate
Then the "Jello Killer" plate. Here's a cheap one from amazon https://www.amazon.com/dp/B00KHGR4FQ?psc=1
Then I use a RetiCam to hold the phone http://reticam.com/product/smartphone-tripod-mount-standard.php
6,551
8,203
I'm on an X brace....always worked perfect till I got my new phone.
Thanks all!
I am using the X brace mount with suction cup to the windshield. Will check out the other ram mount for iPhone 7.
Harry's doesn't have any stabilization setting that I can find. If the other ram mount doesn't work, I will try track addict.
