Has anyone used this oil cooler
1,041
1,091
Monaca Pa
Never mind I bought it…
6,519
8,155
let us know how it works out.
898
544
The Mishimoto filter adapter does not fit well at the o-ring mounting surface to the block adapter. The sizing is slightly off an it causes damage to the o-ring / gasket over time. Also, the cooler is not going to be big enough if you remove the Ford water to oil cooler (which actually works really well despite what you read on this site or others).
With size of the Mishimoto cooler, I would run it in conjunction with the OEM water to oil cooler. That type of small air to oil and OEM cooler combo has worked well on a number of other cars I have installed coolers on in the past.
If you want to eliminate the OEM water to oil cooler, you need something the size of a Setrab 948 or 960.
1,041
1,091
Monaca Pa
2012-Boss
A friend of mine who built race engines back in the day most of them on Whelen modifies and had a SK mod said they tried the Ford water to oil cooler on their cars. He said they were useless.
I do have a Setrab sandwich plate that I bought from thelostotter .
898
544
The OEM water to oil cooler is marginal by itself. But, so are small air to oil coolers. Combined together, they work well. That is from practical, hands on experience installing and driving S550 and S197 cars on track. Expect your oil temps to be in the 300 degree range if you push your car hard with just the Mishimoto cooler. If you keep the OEM cooler, you might run 270 - 280. If you want cooler temps than that, you need to jump up to a 948 or larger.
1,041
1,091
Monaca Pa
I’m hoping with going from 8qt gen2 oil pan to the GT500 12 qt pan should reduce temps. I only do track nights once a month. If I have to I will go bigger. I’m running out of money building my new engine and up grading every thing associated. Kooks headers , Ben Calimer stage 2 trans etc I’m will be up to $15000. Trans cooler project is under way.
898
544
I get it. Try to keep the water to oil cooler with the new air to oil if everything will fit. It will help to reduce oil temps (but at the cost of slightly higher coolant temps). I am helping put together a number of motors this winter with friends and they are going to run anywhere from about $9k - $15k depending on the build. It adds up quick.
It’s got to be better than the one on my car from Ford lol
Don’t be too certain about that. It’s main advantage is adding surface area that cools via air. But if you plan to run it stand alone and take off the stock cooler it’s not enough. Either run the two in series, or return/sell this one and get a bigger unit.
The OEM cooler works well when it needs to. And that’s when oil temps are significantly higher than coolant temps. Like a delta of 30° F or more, and it’ll cool more/better than that Mishimoto.
