I installed a set of front and rear Hawk HPS pads. The rear set did not have the clip on them to let you know when the pads are worn. Does anyone know if this is the way the Hawk pads are designed?
dlsdj said:Not the spring clips on top of the pads but the wear indicator on the inside pad so you know when the pads are worn.
