2006 Mustang 3v
Setup last fall:
- Bilstein dampers with H&R Race Springs and J&M Camber Plates
- Whiteline Watts
- BMR spherical LCAs
- Whiteline rear bar full soft
- BMR 35mm front bar full stiff
- 3.73 gears with a Boss Torsen diff
- 4 piston brembo up front and Carbotech XP12 pads
- factory rear brakes with Porterfield R4 pads
- 18x10 wheels with 275 Conti slicks
This setup was very simple, yet very effective. The car had immediate turn in, neutral balance, and could induce rotation/oversteer via the throttle on corner exit if desired.
Over the winter, my car underwent quite a few changes. Things of note:
- MCS TT1 Coil overs and Vorshlag Camber Plates with 550/250 springs replaced the Bilstein setup
- 305 Conti slicks on the same 18x10 wheels
- Removed rear sway bar
- Lowered RC pivot on watts from top hole to bottom hole
First track day out with those parts was a huge mess. Understeer everywhere, rear brakes were locking up under braking, zero turn in response or feel. I played with damper settings a little bit that day, but the car was so bad that I knew a lot of things were going to change so I didn't spend too much time at the track adjusting. Arrived with +8 rebound in the front, and +4 in the back. Finished the day on +9/+8 and there was a hair less understeer. Despite all of this, I improved my PB by 1.5 seconds so I was generally happy all things considered.
Next scheduled track day was a month out, so I knew I had to get busy with the adjustments I thought it needed. First take was to reinstall the Whiteline rear sway bar on the softest setting. Next I replaced the rear calipers, rotors, and pads (oem pads in case my issue was too agressive of a pad, even though it had worked fine last fall). I also backed the rear rebound down to +6.
This resulted in a much more balanced car with no braking issues. I still had hardly any turn in response, but I chalked it up to the 305 tire being a little bulged on the 10" wheel. Still lots of understeer, but I could rotate with the throttle now (before it would just push more). Overall happy with the direction I was heading in, however I destroyed two tires that day from what I thought to be a lack of camber. I later realized it was likely from all the understeering/push happening in a couple of the long sweeping corners and just ripping the tread off. Track Addict didn't work at all, but based on me pacing one of my friends during a session and seeing his times, I suspect I was able to improve my PB by roughly 2 seconds. Not what I wanted, but I will take it.
Last weekend I went back to my home track in hopes of establishing some consistency with the car. Having killed off my slicks, and not wanting to destroy another set of slicks in just one day, I chose to run on some very heat cycled 275/35-18 BFG Rivals. I used to track drive on these a few years ago and remember the postive feedback they gave so I thought it would be a good baseline to work from. Chasing down a shimmy from the front, I repalced the control arms with OEM GT500 units as well as the inner and outer tie rods from Moog. Did the alignment myself and set camber to max that the plates allow, and 1/4" toe out. I also wanted to try and alleviate more understeer, thus softening the front bar to the middle setting. Last change was setting rebound to +13 front/+9 rear.
How did it go? Well, ok. Tires visually looked good, but have nowhere near the grip they once had or what I'm used to. Going into the first turn on the warmup lap, I knew it was no good. Turned the wheel, aaaand then the car turned. Zero response and grip, great. With the front bar softer, the car loaded up better than before and actually handled better mid corner then I expected. This time I had lots of understeer on entry, and slowing down didn't do a whole lot to improve it. I also dropped the front rebound down to +9 and there was slightly less understeer. Brakes felt ok, but was getting some lockup on the front which I halfway expected now that most of the bias is up there and the tires don't have as much grip. Took tire temps after each session (laser gun, not a real pyro) and the spread across the tread was very even with the insides being a few degrees warmer. Overall temps of the rear tires were about 25-30* higher than the fronts, may have had too much pressure in them. Dropped them down throughout the day and the gap front to back closed, but the rears were still about 20* more. Tire wear was perfection, which made me happy. PIR is known for being hard on tires, but I saw no problems. Overall, was again fairly pleased with the progress, but the car hsa even worse turn in while not killing the tires, and I was 4 seconds slower per lap compared to last fall (chalking that up to tires and brakes). There is no rear brake lockup, but I have noticed a reduction in overall braking from running the stock pads out back.
So with all this in mind, what is my next step? Here are my initial thoughts, but of course I would love to hear some feedback from you guys.
- Move RC pivot back to the upper hole
- 200 lb rear springs
- Mount another set of 305 slicks on my new APEX 18x11" wheels
- Lower the ride height to gain more camber (will need to open up the strut tower)
- Possibly corner balance
I was expecting more from the coilovers and big slicks to be honest. The old setup was so easy to drive and did what I wanted, but now it's a constant battle. I'm hoping that raising the RC back up will encourage quicker transitions, thus more immediate turn in.
What do you guys think? Any tips or things I'm missing/overlooking?
Setup last fall:
- Whiteline Watts
