- 37
- 11
Hi all,
I installed FR mgt all aluminum radiator and CoolTech oil cooler kit and reschie thermostat after over heating at Road Atlanta during the summer last year. I just ran COTA and my 2011 Mustang GT overheated and went into limp mode. Luckily I brought my sct tuner and reloaded my Steeda tune. So I monitored the oil temp the rest of the day (3 more sessions) and sure enough the oil temps would get close overheating before I would run cool down laps early in the session. I shift (shiftlight) at 6800 every time and run pretty hard before the oil temps climb. I did notice during a run and it overheats, when I pull into the pits the oil temp gauge drops quickly to the half way mark (normal). I don't think oil temp can cool that quick so I think it has to be something else. I contacted Steeda if they could do anything and Matt (Steeda tuner) stated some other stangs have had the same problem but was coming from radiant heat off of the alternator. The alternator heat was affecting the oil temp sensor. Have you guys heard of this? If so, what was your solution? Sorry so long and thanks in advance, Steven
