HOD "Do the Screw in Your 302" Special Event August 25th
Here's a side-by-side comparison of an event I did last year vs the HOD event:
http://www.youtubemultiplier.com/5227ad19cc38d-laguna-seca-mustang-comparison-before-and-after-lc.php
8,671
2,640
What camera are you using now? Hero 3?
neema said:
My old Ford Racing "GT500" mufflers ticked off a 92.9 dB last year (that was with a magnaflow catted X pipe too). 90 dB is a tough target to hit if you really want to go all out on the uphill past the sound meter. Dense clouds and cooler weather will only make it tougher to pass. Maybe look into some turn away tips?
103/105 dB is significantly louder than 90 dB. You should be fine with a Borla touring, at least on LS. I don't know where the sound meter(s) is/are on Thunderhill
Yup ... Once I get the exhaust, I was going to look at the turn away tips as well since these will be track only, and I don't really mind if the tips of the muffler get replaced or made to be not as "pretty" to accommodate them.
If you're okay with modifying the mufflers, look into supertrapps.
Do The Screw In Your 302 Two is on! Saturday August 30th. Read about it at the thread below.
https://trackmustangsonline.com/index.php?topic=6685.new#new
