So instead of spending $$ on a new grill I decided to make my own, since the only benefit I can see from the 302S grill is that there is some mesh over the fog light holes.
I just used some wire mesh from home depot, gave it a spray paint, cut to size and blocked off the fog light holes, center grill and I also did the same for the lower grill.
To get at the lower grill you must remove the bumper cover.
This is to mainly block off all LARGE bugs that will clog up the radiator and A/C condenser. Plus increased airflow from the fog light block off plates.
Cost about $15 in materials.
