- Thread starter
- #101
Another interesting step in development. I'm trying to sort out the install in my wiring challenged head. It looks like this will not just be added into the already complex wiring but replacing some component(s). Does it eliminate the fuse box? Is the OEM fuse box the equivalent of a Power Distribution Module (PDM)? The wiring diagram on AIM's website doesn't seem to include all the components in the S550 electronics. I remember reading somewhere in TMO that the number of CAN buses went from 3 to 5 in the change from S197 to S550. In addition to your ambitious and talented mechanic ability, are you an electronic talent too?A much anticipated package came in this weekend. Been on the hunt for an AIM PDM/dash/logger system for some time. Now just to decide whether to also run a setup in the kit car
Correct - the PDM replaces the OEM fuses, relays, etc. Here's a pretty good overviewAnother interesting step in development. I'm trying to sort out the install in my wiring challenged head. It looks like this will not just be added into the already complex wiring but replacing some component(s). Does it eliminate the fuse box? Is the OEM fuse box the equivalent of a Power Distribution Module (PDM)? The wiring diagram on AIM's website doesn't seem to include all the components in the S550 electronics. I remember reading somewhere in TMO that the number of CAN buses went from 3 to 5 in the change from S197 to S550. In addition to your ambitious and talented mechanic ability, are you an electronic talent too?
Yes. Go like hell Kevin.
I'm just going to keep liking this on every platform I see it on. Don't mind me.
I recall someone (Tob?) talking on maybe Mustang6g about how good the Ford ABS system is. Any concerns moving off of the Ford ABS setup?Correct - the PDM replaces the OEM fuses, relays, etc. Here's a pretty good overview
In regards to the mustang - it's going to replace everything (all OEM wiring, fuse boxes, computers/modules, etc.). I'll need to go with a standalone EPAS system (either FP350S or Cortex module to trick OEM), standalone ABS (Bosch M5 ABS), and either a Ford control pack or compatible aftermarket ECU (like Link). My goal was to remove all non-necessary areas for simplicity, weight, and adjustability.
As far as install - I've done enough electronics to be dangerous. But it will be a big uphill battle to get it done right. We'll see if I can do it myself or give up and enlist GSpeed to help me finish it
Only in the fact that there will be some teething issues. But the Bosch ABS Module is what every high-end factory race car on the planet uses - def not concerned about its capability/safety. Only my ability to get it working/tuned right. But I'll probably work with a pro once I get the car to that point.I recall someone (Tob?) talking on maybe Mustang6g about how good the Ford ABS system is. Any concerns moving off of the Ford ABS setup?
Absolutely. The FP350S unit is especially capable - really, really great at maximizing grip with slicks. But in the end, as you mentioned, it doesn't offer adjustability and can only do what an OEM-built module is capable of doing. It's a great backup solution for me if I can't/decide against the Bosch since it can also work standalone.The Ford ABS system (especially with the FRPP/FPP controller module) is one of the best OEM systems you can get that will work well on the track (and does it inexpensively, too!), but the BOSCH M4/M5 systems are the professional motorsports benchmark and offer adjustability that you just can't get otherwise.
The only other thing I would suggest (strictly from a cost perspective) is a BMW Mk60 ABS swap; but you don't get the adjustability and I can't say that it would be significantly (if any) better than the Ford system w/ the track module.
Saw this last night?
Are you painting the inside of the car?
You said the cage was going in next so made me wonder.
Not going to lie, the swag from having air jacks will be pretty fun. A definite bonus!Well regardless of the make, this should raise the intimidation factor for you when at the track!!! Look forward to the post when you get her off the ground ( yes, that would be a double meaning , ha ).
