How to cut front bumper off 2009 GT?
54
47
South Carolina
I purchased the Ford Performance front race bumper and tow ring a couple months ago. When it finally quit raining this weekend I started to install it. Bumper cover came off easily, and I had some related work I needed to do on it. Got the eight bolts out of the stock bumper and opened a ten-pack of cutting wheels. I went through four in under fifteen minutes and barely touched the welded-on bumper. Grabbed a Sawzall and some heavy duty metal cutting blades. I could almost hear the car laughing. For those who have replaced the stock bumper, what did you use to get it off? I don't really want to trust the car to a body shop--much less pay for demolition work. Thanks in advance for your advice.
1,163
2,121
SoCal
There’s 4 spot weld that need to be drilled out with a spot weld bit - example below. The angle on one of them is a bit challenging if I recall, but really didn’t take long.
54
47
South Carolina
Have the bit. I was trying to cut the mounting plate from the bumper itself. To be clear, the red arrows point to two of the spot welds? Thanks again for your help.Inked20230529_153300.jpg
1,163
2,121
SoCal
Have the bit. I was trying to cut the mounting plate from the bumper itself. To be clear, the red arrows point to two of the spot welds? Thanks again for your help.View attachment 86628
Here’s a pic from the backside - there's actually 3 spot welds per side - 2 on the top, 1 on the outside bottom.
54
47
South Carolina
Thanks very much for the tip(s). Bit worked perfectly and got the new bumper installed and buttoned up everything last night. My car must have been a Friday build--only had two welds on the passenger side.
