This is the Build Thread for 2017 Mustang GT Performance Pack. Reply below.
Low compression on cylinders 7-8, ring land failure on #8 and #7 was also starting to crack. Rebuild is in process now - the guy I am using for my machine work says it looks like detonation damage.What prompted the engine rebuild?
It would ping pretty bad during high load conditions immediately after loading the tune but the car would eventually "learn" the fuel and driving conditions because the knock would go away after a few miles. The octane adjust option didn't really do anything.That's somewhat surprising to me. The Coyote's do a pretty good job of pulling timing on their own when knock is detected. I'd love to see the minimum timing table for the PP2 tune.
The crank bolt and oil filter adapter are the only things left, I made sure I don't forget!Hey, don't forget to torque your crank bolt.
JK, looks great!
They are American Racing Headers with 1 3/4" primaries. The whole exhaust is ARH and I added two Magnaflow 14419 mufflers after the x-pipe to help quiet the car down.What kind of headers are those? They have a really nice collector!
I didn't have to do anything to get the clearance where it should be. I used ARP main studs and they include a sketch to shorten and counterbore the oil tube spacer so it sits on the stud correctly. I did that and the clearance worked out to be 0.270". Moroso recommends 3/16" to 1/2". No oil pressure issues so I guess it is fine.Kudos on the engine work with doing it yourself. I haven't had to dig into a Coyote yet besides timing equipment /oil pan, just modulars (knock on wood I hope I don't have to anytime soon). Did you have to clearance the oil pick up stand off for the pan?
