HRE FF15 in 19" fits the GT350/R
Dig-It
Kevin
238
8
VA
The test fitting was successful! I was really hoping this was the case. I bought a set of 19" HRE Flowform Monoblock FF15s for my BOSS 302 and kept them because I was told they'd fit a S550 Mustang, including the GT350. I installed Hoosier R7s on them and have really enjoyed over a couple of track weekends.
They are:
Front - 19"x10", 40mm offset; 295/30R19 tire
Rear - 19"x11', 55mm offset; 315/30R19 tire
Weight doesn't appear too far either: Approximately 1-2 lbs heavier than GT350R stock wheels in the front and approximately 4 lbs more for the rear.
Yes they clear the brakes. The 19x11 weighs 23 lbs and can be run square with spacers. CorteX has all the info including the wheels and 1/2" wheel stud kit so you can use spacers.
Dig-It
Kevin
238
8
VA
Not yet. I've been away on business for a bit. I'll be able to get back to you on this within the next couple of months though.
VoodooBOSS said:
@Dig-It did you try the 19x11 up front on your GT350 and if so how much spacer did you need? Any photos of them mounted on your car?
I didn't see a response but here is the information.
19x11 ET 55
25 mm spacer
Most are using 3" studs upfront to elimate the need of a adapter that has the studs in there.
Dig-It
Kevin
238
8
VA
But I did respond. I said, "Not yet", and I still haven't. ;)
It might bode well for some, but I'm going to keep running a staggered set up.
Paul, good to see you here at TMO - where the real Mustang owners hang out.
