NYLineman
Owner of #2611 CO
I just bought the LS Gauge Pod and a Ford Racing Oil Temp gauge. Curious to know what other people are using other than the setup Ford came up with. Thanks
+1 unless you throw some boost at it.5 DOT 0 said:Oil and water temp and oil pressure would be the most useful IMO.
couple of guys use themNYLineman said:Anyone use those AeroForce Interceptor Gauges? Keep leaning towards them for their versatility.
I bunch of us have them and they work very well. Easy to install and program. Many of us use the Roush vent pod.NYLineman said:Anyone use those AeroForce Interceptor Gauges? Keep leaning towards them for their versatility.
06mach1 said:I installed Speedhut custom gauges. Water temp, Oil press and Oil temp. They are the Revolution series that has the high and low warning light and also, recall of high and low readings. They require a little bit of work to get them to fit in the the Ford gauge pod, but they are cheaper than autometer and seem to work just as good.
ace72ace said:What was the price for all of the gauges? Did you have buy any extra fittings or accessories? Last I checked LRS has the best price on the 'naked' pod? Is that where you got yours? I really like the looks of this but am having a hard time contemplating drilling holes in the dash if it didn't come that way from the factory like the LS.
I am trying to come up with a way of mounting them on some kind of pedestal or base that the gauges can be attached with industrial grade velcro. This would also hide all the wiring. Taking the dashboard off and then finding a way to securely attach the 'base' underneath and then have it curve around the dash would work. Yeah a lot of work to fabricate something like this, but anything is possible.
PeteInCT said:If I remember correctly the second one piggybacks off of the first one.... I only have one but I thought I saw that in the instruction sheet.
