- Thread starter
- #81
cloud9
Gary
I'd blame me before the car until we prove otherwise I'll be the first to admit I was in learning mode day 1 in a new car. Now if it happens again.......
Especially at nominally $10/qt for 5W-50.Jimmy Pribble said:Since this is now somehow the track prep and cooling thread, I thought I would mention that the 302R oil pan might be a worthwhile upgrade for those who need more cooling capacity. I thought it would just have extra baffling and whatnot, but nope, it increases oil capacity to a whopping 12 quarts! Warning: the price of the oil pan (and oil changes) will make your eyes water:
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=12061
Jimmy
ArizonaGT said:I'm guessing that a Canton aluminum pan will be just as effective...maybe.
Dean#4AI said:Or you could get an Accusump.
I took the shroud covering the radiator off mine yesterday to get a good look at the radiator. It does look to be boxed in very nicely and you're right I don't see a lot of air flowing around it. The grille appears to be impeding a ton of airflow that could go directly onto the radiator. There are three slats around the tri-bar pony that could be opened up plus the faux fog lamps really block air flow. I got to looking at it and I think I could drill approximately 120 (~1/4") holes in the fog lamps to provide additional airflow. It would end up looking like a screen, which is maybe what it's supposed to be replicating anyway? I'm sure it would be unthinkable to many, but I might just try it. I see blueovalindustries.com sells the unpainted grille for $349 if I screw it up.ORANGE CRUSH said:I looked over my radiator and front grill and from what I can see this is the best box in job I have ever seen on a stock Mustang. I don't see much air going around the radiator.
Ford Racing? The white one might look good on Boss cars with white stripes.cloud9 said:Where do I get one of those?
Exactly. I'd like to try the grille first since it will be much cheaper.....at least it better be5 DOT 0 said:Maybe mwilson7 will know. That would go well with the 302S hood.
Yep. I think wmilson7 is busy today though....cloud9 said:Exactly. I'd like to try the grille first since it will be much cheaper.....at least it better be5 DOT 0 said:Maybe mwilson7 will know. That would go well with the 302S hood.
And better hood ventilation.BossJockey said:Hum, and the 302S has a better radiator that the street Boss to boot.
