Inside tire wear on front
I have a 12 Boss with 25K miles with the original Pirelli tires, DD only. The front tires have inside tire wear, to the cords. I have checked the alignment twice and all is in spec. I am checking with Ford tomorrow to see if they will pro-rate the warranty. Has anyone had any similar problems with these tires?
675
253
Like all sports cars, these cars run negative camber up front per factory spec so it is natural that your inside edges have worn down. 25k miles is a LOT to get out of high performance tires on a sports car.
John
John
Yes I agree with this. I think 20K out of the stock Pirelli's is pretty good so I'd call it a good day at 25K. Still the tires shouldn't wear that unevenly so I'd look for something out of spec.
I had the same problem, bought some caster camber plates now running -0.5 deg street and -2.0 track camber settings. Steering response is not as crisp with less camber, but it's a trade off I'm willing to make. Would rather spend money on track days than street tires.
Ranger117 said:
Camber caster and toe are almost perfect within a degree of spec.
Anything near factory spec and I think 25k is great mileage on stock P Zero tires. If you want more, I'd suggest reducing the negative camber by 2/3rds or half. Also run 1 to 2 pounds more pressure. Zero out the toe if you can live with the slightly reduced stability.
Ok, here is my alignment readings
Camber
Left -1.0 Right -0.9
Caster
Left 6.8 Right 6.7
Toe
Left 0.09 Right 0.08
Total Toe 0.17
Setting camber to -0.05 might help inside tire wear some. It is not a toe problem because the wear is on the inside one inch only, not feathering across the tire. I am install PSS on all four.
With Super Sports, I'd just leave the alignment alone. They seem to like a LOT of camber and wear waaaay better than the Pirellis. But that's just a suggestion, since I drive a little differently. ;)
