Interior goop
Jim Ryder
Retriever Racing
46
130
machesney park, ill.
It seems to me I read somewhere that if you scrap out all that goop they put all over the interior it's about 20 pounds?? is that right? I'm trying to remove more weight out of the car this winter so alot of little things may add up right?
1,161
1,159
Lenoir City TN
I would be surprised if it amounts to that much. Most remove it in preparation for seam welding the body to improve rigidity.
531
364
sfo
Wow! Cleanest job I have ever seen. I tried to chisel as much as possible but mostly gave up. The sealer is heavy. I know I have chiseled out pounds of the stuff but still have more to go. Do you have a trick to getting it out? even and airtool does not strip it out as nice as you have done. It looks like you started with a body in white!
Jim Ryder
Retriever Racing
46
130
xr7
TMO Addict?
719
841
Minnesota
I've seen some people use liquid nitrogen to freeze the gunk and then it will break off in chunks.
I recall there being three types of adhesive to remove.
The seam sealer I thought was the most difficult to remove. I used a heat gun and a medium thickness scraper/spatula that was 1.5 inches wide. Heat it up until it just starts to smoke and scrape it off in layers. Once I was down close to the metal I used a worn 4 inch diameter wire wheel in my drill to remove the residual adhesive.
The other common adhesive is on the floor, the trans tunnel, in the middle of the trunk and on the inside off the roof. This is usually in multiple lines with various widths. It is almost dense foam like material. I also used heat and a scraper to get it down close to the metal. I found that the adhesive only had to warmed up to remove. I then use the adhesive remover (pictured) to remove the residual. This worked quite well especially over all the contoured shaped shapes the flat scraper couldn't reach. The adhesive remover did not remove the paint either. Be careful and use low heat on the roof adhesive as excess heat could damage the exterior paint.
The last adhesive is hard to describe but it is like a roof shingle in consistency. I recall it being in 4 places around the rear fender wells and on the drivers side floor. It takes some warm heat and a scraper. It is really gooey when warmed up. I removed the residual with the adhesive remover once again.
I also tried the dry ice idea but it did not work for me as I had seen in several YouTube videos. Maybe it has something to do with the age of the adhesive.
All in I probably had about 24 hours into adhesive removal with 3 wire wheels and 4 cans of adhesive remover consumed. Take your time and wear the proper PPE. The seam sealer really stinks.
I also attached a shot of the interior just prior to paint.
