S197 Is Weight reduction bad sometimes?
Hey everyone! have a quick question about removing weight from my 2012 mustang that I have built for autocross and running Cam-c. I was finally able to weigh my car and it was 3516lb without me in it and a 56% front weight Bias. (3701 with me) I was debating on removing all the trunk carpet and the rear seat from the car, but is this a smart option without transferring some of the other weight from the front of the car back? I get lighter is faster but removing that just from the rear and making the bias worse. It seems like the wrong move or am I just thinking about this the wrong way?
Sometimes, here's an example, the old Ford F150 Lightnings were never as fast as the SUV version, even though the pickup was 400 pounds lighter. They used the same frames and driveline but that extra 400 pounds were over the back tires.
So.. if you can reduce weight do it, but to be able to place that weight where you want it is just as important.
Are you thinking the GMC Syclone and Typhoon?
I had just never heard of any form of a SUV version of any generation of the Lightning and Google isn't turning any up either.
It was an explorer or something, same chassis I've run against the cyclones in NASA, the SUV version would always out handle the pickup.
In autocross, there are some times when I've been faster with a passenger. Usually a car with open diff and FWD, and a course with more RH turns.
All of the above are correct, getting rid of weight helps overall but if the weight you already have is in the wrong spot then you should try to find out what can be removed or re-distributed. A common theme with most cars would be moving the battery to the passenger side of the trunk and removing extra stuff off the front end like the windshield cleaner reservoir and so on...
I'm not very familiar with the rule set for cam so reference that as to what can/cant be touched and figure out what compromises you can live with and how committed you are to building a car for that class.
start finding front weight to remove.. lol
I did not "road course" my S197, but I did lightweight batt, removed washer bottle, lightweight rad support, and alum lightweight crash beam
(which might be a bad idea on a road course car). It nicely offset the Roush blower I added.
Not sure if any of the full "cradle's" hold up to road course use, but that could be another decent weight savings.
Pretty old article, but goes into quite a bit of what Grigg's was doing 10 or so years ago.
https://www.motortrend.com/how-to/m5lp-0707-s197-ford-mustang-suspension/
