Does anyone have any recommendations on some quality jack stands? I'm currently using the Harbor Freight ones and would like to get something more substantial. Please post a link to the stands with your recommendation. TIA
VooDooBOSS said:That's what I'm looking for. These work fine on the pinch welds? Are they stable when placing two on one side and jacking up the car on the other side to place the other two stands in place? My cheap stands rocked a bit which always caught my attention.
Thanks guys, just ordered a set. Like Rick I have always been a little leery of my Harbor Freight ones.Black Boss said:+1
I use the exact same ones. Lightweight and very solid.
I'm sure they're just fine. I have a plastic race deck floor in my garage and I have to use sheets of Masonite under them to avoid marring the floor from the sharp corners. Same issue in the paddock at some tracks where they require you to use boards to prevent sinking into the asphalt. The flat bottoms on these eliminate that issue.Tri-bar said:I use old Harbor freight 3 ton stands. I think they just changed the color to grey.
http://www.harborfreight.com/3-ton-steel-jack-stands-69597.html
Mine are yellow.
I use the Jack stand pads on the pinch welds.
http://www.harborfreight.com/2-piece-rubber-pads-for-jack-stand-95952.html
Never had a issue with them even at the track.
cloud9 said:I'm sure they're just fine. I have a plastic race deck floor in my garage and I have to use sheets of Masonite under them to avoid marring the floor from the sharp corners. Same issue in the paddock at some tracks where they require you to use boards to prevent sinking into the asphalt. The flat bottoms on these eliminate that issue.
