Just a friendly reminder why changing your process before track days is a bad idea (PSA)
741
1,075
TX
I have a super strict oil change and track day prep process (latter includes a detailed nut and bolt check right before I roll the car into the trailer). I skipped the nut and bolt check this time because I was slammed for time and felt confident my post-track day process had me covered (which also includes a nut and bolt check). Welp, that doesn't help when you're an idiot and forget to torque the bolt down.
I have a couple safeties in the car (oil pressure lights + accusump) that would've hopefully come on, but DAMN. I'll give myself the idiot award for the month of May. Add it to the list of reasons not to change your routine habits/processes!
531
364
sfo
saftey wire....don't be that guy who oils the track! I safety wire all drain plugs and my oil filter.
741
1,075
TX
Close call!! I’ve started using this on all of my under car fasteners - really helps with the pre and post inspections.
Yep. I have a few tubes of something similar in pink. Virtually everything is marked with the stuff. Just forgot this time. Oye
Thin?
Wasn't sure how to safety wire this setup, but buddy of mine just gave a good idea about drilling a small whole through the oil pan's support fin. Will have to do that this weekend.
119
81
Atlanta, GA
Good reminder! I do the same with a strict pre/post track day inspection and servicing. I spent 10 years as a commercial pilot. Repetition, following a checklist, muscle memory, discipline, etc. dramatically increase safety and reduce risk. Glad the bolt held on for you! Thanks again for the reminder, it can happen to any of us.
