isrboss
Eric said:Jimmy,
Nope....here're the numbers. I'd have to look under the car to verify front and rear.
343257 // 35115.701
355301 // 35115.702
ISR and Boro,
Concur with the secrecy thing...makes you wonder why. Having said that, for me it was less about spring rates and more about how the system worked. What I didnt want to do was create an ill handling car in an effort to correct ride height and rear roll center. Ford spent some serious R&D coin on developing the Boss, so in my mind simply swapping springs was problematic. I had a similar experience with my 70 Boss as I experimented with different springs, lowering front A-Arms and such only to end up with a car that handled poorly on the street and track. I finally settled on a fully engineered and tested set up from Global West....and the difference was night and day in both environments. So, for me KB's approach was similar to GW...they race what they sell....and its a fully engineered and tested system with each component compatable with the other components.
r
Eric
r/
Eric
Eibach Pro Street-S Coilovers - #35115.711
2007-2008 Ford Mustang Shelby GT500 Coupe, V8-5.4L-SC, S197
2007-2008 Ford Mustang Shelby GT500 Convertible V8-5.4L-SC, S197
Description Part Number Qty
Front Coil Over Assembly 35115.8100 2
Front Main Spring 35115.701 2 =400lbs/in
Front Spacer Spacer250.0 2
Front Helper 0175.250.0150.0 2
Front Bump Stop BS770014 2
Rear Damper 35101.8004 2
Rear Spring 35115.702 2 = 275lbs/in
Rear Adjustable Collar 8000155 2
Rear Bump Stop BS45001617 2
Thanks for the part#'s those are straight from Eibach's gt500. Not sure about the dampers, but Eibach does funny things with part numbers. Perfect rates for a street/HPDE car in my opinion, but why hide that sh*t KB? I'm not sure if I would not run a small sway with that though, but I don't know what goes in to the geometry of KB's 4.0. I hope KB isn't charging an extra $500 for those KB stickers on the dampers!
boro my Eibach/federn with KW dampers is a low quantity(Eibach has started making their own dampers now). It really is simply a KW V1 with red springs, because I bet Eibach supplies the springs to KW they just make them yellow.
