Last night the following wheels were test fitted on my 2018 PP1:
18"x10.5"x25mm offset Konig Ultraform's with 315/30-18 Hoosier drag radials fit over the front calipers with about 1/16" clearance in the corners (lots of clearance over the rears). There's about 3/8" tire clearance from the front strut, and 3/4" clearance from the rear shock. Front and rear, they stick under the fender lips, but are so short that contact is unlikely. At only 21Lbs and $200 each, they're an attractive lightweight.
