kooks side pipes vs stock - any difference in flow?
344
Can anyone give me a seat of the pants or dyno comparison of kooks side pipes vs stock 302 side pipes?
The comparison I am looking for is on a full Kooks LT setup with cat delete.
Just curious to know if I am leaving anything on the table by retaining the stock side pipes on an otherwise complete Kooks setup.
Also, with the Kooks, can the baffle plates be used?
Thanks in advance for any replies.
PeteInCT
2,848
14
Lee - I doubt very highly if there's a difference, since the general belief is that there's no difference in HP with the side pipes in or out, Kooks or otherwise. What H pipe are you using that still supports the stock H-Pipes? I'm not a kooks maven (yet ;-) but Cloud9 has a lot of good experience. I thought that the optimum setup was to remove the side pipes altogether and switch to a different H-Pipe. All of this I thought was from Kooks, from the LTH's all the way back (?).
Oh Mr. "1'st place in your Class", can you help us underlings ?? (back handed complement to Cloud9, otherwise known as "Mr. Speedy" ::) )
-Pete
4,018
1,964
Lee
From a performance stance I would bet you would gain more by running 1 7/8" or 2" primary tube headers, 3" x pipe and 3" over axle pipes with lighter free flow mufflers like Corsas eliminating the side pipes will save weight (20lbs) and your hearing. There isn't enough room under the floor pans to run a side pipe that can flow enough to increase power. Now if you are doing it for sound the Kooks side pipes do scream louder than the stock Boss pipes.
344
-Pete
Pete it is Kooks all the way back & I would agree about flow since it is generally known that the side pipe is basically for sound.
- None-the-less, just thought I'd ask.
Thanks for replying.
Lee.
- Are you going to NJMP 5/16-18?
PeteInCT
2,848
14
Steve's answer is the more lucid ;D What he states is what a number of people have done with good results. That setup seems to be the best bang for your buck as far as an increase in real horsepower is concerned.
-Pete
344
steveespo said:
Lee
Steve, are you running 1 7/8" with a CJ setup, & if so how what hp/tq did you get?
thx
4,018
1,964
Lee
Haven't got the CJ on yet. I'm going back and forth with Shaun at AED about writing the tune. My data logs at idle show a lean condition that I believe is either the O2 sensors or dirty MAF. I eliminated the vacuum leak as a possible reason today. The WOT logs look good but Shaun is a PhD of tuning and he won't release one unless the logs show all is well.
I do plan on using my 1 7/8" ARH headers since they are on and I am NOT doing that job again. I did hear that 2" primaries are worth some power with the CJ manifold.
344
steveespo said:
Lee
ok & thanks.
- what about tq lower down on rpm with the larger pipes?
Any trade off?
