- 56
- 0
Installed a Beltronic STiR Plus radar detector and a Laser Interceptor laser jammer.
roadhouse said:Now THAT is the way to install a radar/laser detectors and jammer! Well done sir.
Love the grille too.
milestogo said:Thanks. I've already been saved a couple of times. I drive fast but safe. The big brembo front brakes and forgestar wheels turned out well also. Very happy with the cosmetics.
Darth Boss said:Love it. Did you install it or have it installed? Curious to what this would set someone back.
What grille and springs do you have installed?
unrealford said:What happens when you go through Ohio? They have monitors they detect radar Detectors. I know of 2 friends that just passed the border into the state and immediately got pulled over and they took possession of them and fined heavily..
cbj5259 said:I know in Virginia they are illegal too.
Here in PA they are allowed but are useless since the police here don't use Lidar and only the State Police use non moving radar. The local police use electronic speed timers such as ENRADD and Vascar which are undetectable.
milestogo said:ENRADD is very rare because it is difficult to set up and certify. As of now, I think it is only used in Pennsylvania. Vascar is most definitely detectable. I have a very nice aircraft detector in my BMW but didn't put it in the Boss (yet) because it's only used in a few places in FL. I use the Zaon PCAS MRX with a remote front mounted antenna for VASCAR. It is 100% reliable.
cbj5259 said:Sorry but Vascar is not detectable. It stands for Vehicle average speed computer and recorder. It is simply a computer that calculates the average speed between two fixed points (trees, mailboxes, painted lines in the roadway). It is operated by the operator actuating a stop and start switch when the target vehicle passes the two preset points. It does not eminate any type of signal. We use it in patrol cars, not in aircraft (well the state uses it in their helicopter, but that's it). Almost all Vascar use in PA is done by ground units. Its basically an advanced stop watch. Enradd is widely used in PA. Every department in my county uses it. It takes about 2 minutes to set up. You may be thinking of ESP, which was a PITA to set up.
