I have read quite a bit about the Launch Control that is part on the Track Key program. People are saying it is too much trouble to set each time and that once you shut off the car you need to reset it each time. Is that true? If at the drag strip and you find the best rpm for the conditions do you need to reset each time you restart? If so that would be a pain since you could get pressured for time on your last start up in the staging lanes prior to your run.
Ralph
Ralph
