I know how to turn the Launch Control and adjust it, but is there a way to turn it completely off?
good info that will come in handy next trip to the stripCaliMR said:Remove the Track Key ;D
You can leave the clutch a smidge off the floor, rev past the LC setting, then put the clutch to the floor and it will not drop your RPMs. Then just avoid dropping it back below the setting. That seems to be the best work-around so far. It doesn't seem like you need higher than the max unless you are on drag tires though.
MrGT5oh said:I know how to turn the Launch Control and adjust it, but is there a way to turn it completely off?
DigiCowboy said:MrGT5oh said:I know how to turn the Launch Control and adjust it, but is there a way to turn it completely off?
Won't setting it all the way up (5000 rpms?) solve your problem? or do you use it sometime and want to get around it others?
yeah I launch around 6600 at the track on slicks.95blitz said:DigiCowboy said:MrGT5oh said:I know how to turn the Launch Control and adjust it, but is there a way to turn it completely off?
If he is launching on slicks he may want it set higher.
Not to sure what you are trying to explain. I always start the car with the screen blank. you use the far left button which is info. if you press it with the trackey enabled still up it says press reset to clear. so I tried starting the car with it blank and leaving message displayed and cleared....still worked. and tried starting it on another screen then scrolling it to the blank screen (wont let you still you press reset to clear the trackey enabled) and still nothing. wish you could just hold down something like you can with the idle feature to disable it.reakhavok said:I think the other day I turned launch control off.. I was actually going to show someone the feature and it was not working, so I turned the car off and back on and it then worked. I need to test this again, but gave the car to the shop to get my new tiger hood installed.. Anyway, someone test this please.
to disable launch control press the setup button (i think whichever one is on our far right). so that your LCD screen is just blank. Instead of "trackey enabled". This is the only thing I had done bc I wanted to see what my MPG's where so after cycling thru those menu options I kept clicking until the screen was blank.. at the end of my trip when I wanted to show off launch control it didnt hold and went all the way to redline. I tried 3 times and was really confused as to why LC failed. So I shut the car off and back on, "trackey enabled" reappeared and launch control worked fine. As I laid in bed that night i started to think about it again and then realized I may have found a way to turn LC off..
someone please give it a shot and let me know!!!
I tried it just pushing in enough to disengage the clutch. maybe adjust some switch under there?CaliMR said:Was your foot all the way down on the clutch? If it isn't touching the button at the bottom, it will not enable LC.
its in the instructions that come with the voucherSteve said:What do you hold down to disable the idle function?
boss2511 said:I tried it just pushing in enough to disengage the clutch. maybe adjust some switch under there?CaliMR said:Was your foot all the way down on the clutch? If it isn't touching the button at the bottom, it will not enable LC.
you know the switch that detects the clutch pedal position maybe yours in a different spot than mineCaliMR said:boss2511 said:I tried it just pushing in enough to disengage the clutch. maybe adjust some switch under there?CaliMR said:Was your foot all the way down on the clutch? If it isn't touching the button at the bottom, it will not enable LC.
huh?
