LCA Install
Hi
I just purchased the Kenny Brown sport LCA + bracket and I have some question for the installation.
As you can see on the picture I got a space between the LCA and the bracket.
It's about 3/16 wide (5mm). Do you think it's normal? I will call Kenny Brown shop. I just didn't have time yet.
Also the spacer that replace the original LCA is too small too but only 1/16 (1mm)
What you guys do you think?
I didn't tight anything. When I saw that space I remove everything and ask if it was normal.
I thought it would have been a more tight fitting.
Do you think it would be OK between the LCA and the bracket because it's a huge gap.
Thanks
It's been a while since I installed my Steeda LCA's. I'm 90% sure they included large steel fender washers to fill the void. I would not torque those ears down. Something isn't right.
Swiss Boss said:
Hi
If you haven't called Kenny B . You need to call. I think that they have sent you the wrong LCA kit for your car. I have Metcos and they slid in tight , no gaps.
