Not to hijack the thread too much....
I installed the FRPP LCA's and relocation brackets. Love the final product as well as the inproved traction and rear end stability.
One issue I had was with the rear bushings separating from the arms. The four ends share a common bushing half, 8 per kit. The halves simply slide in, press in from each side. A steel sleeve one inch in diameter slides into the two halves. the rear sleeves are about 1/2 half inch longer than the front. The front portion of the arm with bushings fit snuggly into the opening in the body. The rear with the longer sleeve fits into the LCA lowering bracket. Unfortunately the rear bushing halves are not firmly retained by the bracket as the fronts are.
After just a few miles the bushing halves on the rear started to back out of the LCA. With the approx. 1/2 inch gap from the bushings to the inside of the bracket, this had to happen.
To fix this issue I purchased a stack of 1" washers and 1" shaft spacers, basically smaller washers which fit between the washers to snug up the fit. End results are bushings halves that stay in place.
Has anyone else with the FRPP tube type LCAs, noticed if their bushings have worked their way out of the arms?
Thanks
Thanks
